Heute am Teutoburger Wald bei Werther....
Beiträge von moppi1962
01 Allgeier72_______1__________rot , optional schwarz
02 Ginger__________1__________schwarz
03 Twinner_________1__________Rot, optionalschwarz
04 E03____________1__________schwarz
05 Haki____________1__________schwarz
06 Castolin_________1__________schwarz
07 AT-Raz__________1__________schwarz
08 Kunibert_________2__________schwarz
09 Grobmotoriker____1__________schwarz
10 sensor611_______1__________schwarz
11 ADri____________1__________Natur
12 zeckoried _______1__________schwarz
13 TrentXWB_______1__________schwarz
14 Maddin271______1__________schwarz
15 #KU___________1__________schwarz
16 Ingo___________1__________schwarz
17 Maddan________1__________Alu "natur"
18 4x4____________1__________Rot - optional schwarz
19 Atwin Rider______1__________schwarz
20 stiegie__________1__________schwarz
21 CP1960_________1__________schwarz
22 Rolando_________1__________GOLD /optional Natur
23 Moped 11_______1__________schwarz
24 willimaja_________1_________schwarz
25 raso____________1_________schwarz
26 MoD____________1_________schwarz
27 uek1600_________1________schwarz
28 AT-ANDI ________1________gold , optional rot
29 Lumpi __________1________schwarz
30 rocchas_________1________schwarz
31 Bajus___________1________schwarz
32 R0adrunner______1________schwarz
33 ATFan__________2________schwarz
34 CRF ____________1_______schwarz
35 AT66____________1_______GOLD; optional schwarz
36 DoubleTwin_______1_______schwarz
37 Supermagnum____1________rot, optional schwarz
38 Pe7er___________1________schwarz
39 Tom____________1________schwarz
40 AT Treiber_______1________schwarz
41 HaraldS50_______1________schwarz
42 iceman _________1________schwarz
43 Frickelmaster ____1________schwarz
44 rocketmann34212___1______schwarz
45 MrStone_________1________schwarz
46 Don_____________1________rot, optional schwarz
47 Wölfchen_________1_______ schwarz
48 othiel1984________1________schwarz
49 zio callo__________1________Natur
50 Bertolucci________1________schwarz
51 tscharlie_________1________rot, optional schwarz
52 elbotanico________1________schwar
53 AT Rocker________1________Rot, Optional Schwarz
54 XEHRs-Reisen _____1________Natur
55 schnuschnau______1_______schwarz
56 Tommes__________1_______Schwarz Optional Gold
57 Kurvenkrycher_____1_______Schwarz
58 Speesarthirsch_____1________schwarz
59 der FranZ_________1________gold /optional natur
60 Ted______________1__________Alu "Natur"
61 Mandi5162________2________schwarz
62 c13______________1________schwarz
63 hatschky__________1________schwarz
64 OstseeAT_________1_________schwarz
65 RDThorsten_______1_________schwarz
66 raytek____________1__________Gold/optional Alu "Natur"
67 hrau_______1_________schwarz
68 moppi1962_______1_________schwarzNehme ich gerne
Zitat von rubbergumAlles anzeigen
Geil...Danke!
Zitat von MaddanAlles anzeigen
Ich habe selber was gebaut. Passt auch zu den breiteren Fussrasten. Auf das plane Teil der 8mm (nach fräsen der Zacken immer noch 6mm) starken Druckplatte aus Alu kann ich bei Bedarf (viel stehende Fahrt) noch ein Stück draufschrauben. Die Halterung der Platte liegt auf der ganzen Länge am Bremshebel auf, ist mit einer M6 im Gewinde in der Halterung verschraubt und mit einer Stopmutter gesichert. Am originalen Hebel wurde nichts geändert, auch das 6er Loch ist bereits vorhanden. Rückbau auf Original jederzeit möglich.
[attachment=0]DSC_0722.JPG[/attachment]
Wow..Respekt....Ne Fußrastenauflage kann nicht jeder bauen...ich z.B. nicht
Hallo zusammen
Gibt es irgendwo eine größere Auflage für den Fußbremshebel?
Fahre seit einigen Tagen mit alpinstars Toucan Schuhen und habe null Gefühl beim bremsen.
Eine größere Auflage könnte ggf. etwas Abhilfe schaffen. -
Zitat von BrockAlles anzeigen
Ähm... Vielleicht verwechsel ich da was. Aber dem Hepco & Becker Griffprotektor ist es völlig egal, wie hoch dein Lenker ist, da sich die einzigen Montagepunkte ebenfalls sämtlich am Lenker befinden. Ich habe auch eine Lenkererhöhung 30 mm verbaut, entsprechend müssen nur die Schrauben ebenfalls 30 mm länger sein. Wenn man das bei der Bestellung mit angibt, packen die bei Hepco & Becker zusätzliche längere Schrauben mit bei.
Gesendet von meinem SM-N910F mit Tapatalk
Hi!
Das wäre auch meine Frage. ich habe die 30mm Lenkererhöhung von SW-Motech im Regal liegen (noch nicht verbaut) und plane auch, mir die Hepco & Becker Griffprotektoren zu kaufen. Also eine Info an H&K und dann gibt es entsprechend längere Schrauben dazu?
Das wäre ja super. Dann würde ja wieder alles passen.VG
Matthias
