Nach dem Gold-Wing Amerika es geschafft hat ein Update zubekommen für Andriod-Auto,
hier der link dazu zum Download: https://motorcycle.honda.ca/gold_wing/navi-update
Bei mir ging der Downlod nicht direkt, erst über die Statseite - Goldwing - da findet ihr den Link.
Beschreibung:
What You Will Need
A USB flash drive with at least 16 GB capacity.
A computer with a high-speed Internet connection.
Between 30-60 minutes of time. Connect a battery charger to the unit if unsure of the charge state of the battery.
This latest version, designed for 2018 and newer Gold Wings, offers the following improvements: (Download Software Manual)
Add up to 99 waypoints per route.
Increased XM source hold in low-signal areas
Improved iPhone XS, XS Max and XR compatibility
Added Android Auto integration
Adaptive audio equalizer function that adjusts for riding noise
Added auto navigation volume function
Increased map colour selection
Home destination can now be set from the menu
Added estimated time of arrival function
Added speed limit icon on the map screen
Ist eine ISO. Datei 8,3 GB groß zum Download, hab keinen Schimmer ob die bei den AT´S klappt
Ein schönes Wochenende
